It is currently Wed May 20, 2026 8:53 am
 Post subject: Calling truck owners!
PostPosted: Mon Aug 22, 2016 3:55 pm
Anybody out there own a shortbed 72-up D100/150 equipped with a 904 and a 9.25 rear axle? If so, any chance you could measure the length of your driveshaft from center of u-joint to center of u-joint for me? I am switching my truck from a 727 to a 904 and would like to have the new driveshaft ready to install on the day of the swap.
Thanks!
 Post subject: From the DC race manual
PostPosted: Fri Sep 16, 2016 7:12 am
From centerline of front u-joint to centerline of rear u-joint should be 3.5" less than measuring from rear of transmission extension to centerline of rear axle yoke (u-joint seat).
Advise should be taken as ongoing, that way, when you get to realizing what you are doing you can include yourself.
PostPosted: Fri Sep 16, 2016 7:22 am
I'm sure you know this...but, remember the front yoke is different.
I'm going to attempt to fix this project and not make it any worse.
PostPosted: Fri Sep 16, 2016 7:48 am
My post was put in so if you don't find a drive shaft, you can make one.
PostPosted: Fri Sep 16, 2016 8:49 am
Thanks. I have a new front yoke and extra driveshaft already. The 904 driveshaft should be longer than the 727 shaft, right? So measure the 727 shaft and add 3.5 inches?
PostPosted: Fri Sep 16, 2016 8:32 pm
The first post by me was if you have no drive shaft, with the vehicle sitting at curb height and ready to install drive shaft, the u-joints one the shaft should sit 3.5" shorter than from end of tail shaft to center of rear u-joint on the pinion yoke.
In other words; measure between the end of installed transmission tail housing (not tail shaft) to the center of the pinion yoke (rear u-joint center in effect) and the u-joints on the new driveshaft should be 3.5" shorter than that.
The 727 trans. is about 4.2" longer overall but I don't know the difference in the yokes.
