It is currently Thu Nov 12, 2026 6:09 am
Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2
PostPosted: Thu Sep 22, 2016 12:37 pm
I have a EGR valve unit which I have cut the plunger. But I still have it all. You could jimmy it back together so it looks like it is working. You can have it I just need a few $1 or 2 to mail.
66 dodge dart 270, 225ci, 3.7l, L6
PostPosted: Thu Sep 22, 2016 12:47 pm
I'm trying and failing to figure out why he would want to do this. :shrug:
PostPosted: Thu Sep 22, 2016 4:28 pm
I thought the OP was trying to pass a visual smog inspection?
PostPosted: Thu Sep 22, 2016 4:51 pm
Yes, and an EGR valve (an actual, real one, which presumably he already has) is part of doing so. So I'm still baffled by your suggestion.
PostPosted: Fri Sep 23, 2016 7:55 am
Probably because it would be the equivalent of having a blocked off EGR port but it would look like a functioning one? Like gutting a cat.
PostPosted: Fri Sep 23, 2016 11:27 am
The right way to achieve that result is to just flip the EGR valve on the intake manifold and pu aomehting like a golf tee stem up the vacuum hose for the EGR. Cutting the stem has rendered that EGR valve useless for anything but ballast or scrap.
PostPosted: Fri Sep 23, 2016 2:12 pm
Is there a market for used egr valves?
PostPosted: Fri Sep 23, 2016 3:20 pm
None that I am aware of.
PostPosted: Fri Sep 23, 2016 4:43 pm
.......ok......well then why is it a big deal to render the egr valve inoperative/make it scrap?
PostPosted: Fri Sep 23, 2016 6:45 pm
Plowing through the engine bay yanking and cutting and disabling stuff because "That's a pollution control, so I'ma git rid of it!" is a thoughtless and unreasonable thing to do. See here. Same goes for cutting or gutting the cat (meow), see here.
PostPosted: Tue Sep 27, 2016 6:50 am
I guess I was more addresisng this:
"The right way to achieve that result is to just flip the EGR valve on the intake manifold and pu aomehting like a golf tee stem up the vacuum hose for the EGR. Cutting the stem has rendered that EGR valve useless for anything but ballast or scrap."
I had asked if the EGR valve -- a used one nonetheless -- is particularly valuable.....and was told its not.....
Wont get into the whole pollution control topic because I know thats just like discussing religion and politics and "best oil to use". LOL
I am not a particular believer that the early pollution controls were particularly good/functional.
Kind of like those dang new plastic gas cans....they make them so no extra vapors get released while in storage. Except in doing so they have designed them so that I spill more gas while trying to use them and therefore causing more pollution than the vapors would have probably caused with the old cans. LOL
Users browsing this forum: Ahrefs [Bot], DuckDuckGo [Bot] and 9 guests
