It is currently Fri Nov 13, 2026 8:50 pm
 Post subject: What is this plug?
PostPosted: Sat Sep 24, 2016 11:51 am
Is the pipe plug on the right rear side of the block a water port or oil port?
PostPosted: Sat Sep 24, 2016 12:01 pm
Block cleanout port to drain and clean out the water jacket around the cylinders.
PostPosted: Sun Sep 25, 2016 8:22 am
Ah.....ok.
So not a good place to insert a temp gauge probe I guess?
PostPosted: Sun Sep 25, 2016 9:23 am
Temperature sending units are best placed in the cylinder head or near the outlet / coolant exit point so you can get a reading from the hottest running zones in the engine.
Based on that... the thermostat cover is a good location for an aftermarket temp gauge.
PostPosted: Sun Sep 25, 2016 11:01 am
Do they sell thermostat housings with that already drilled out or is this a home brew sort of deal?
Is there enough room in the housing for the thermostat if the sensor is mounted in it like that?? I just looked at my housing and how the thermostat sits in it and it looks like there wouldnt be room.
I guess I can always go this route
https://www.summitracing.com/parts/atm-2281/overview/
