It is currently Sat May 30, 2026 9:25 pm
 Post subject: Distirbutor gear choice?
PostPosted: Sun Sep 25, 2016 7:58 pm
Looks like the local auto parts joint has two choices....a plastic and a bronze.....$3 and $19 respectively.
Before we started our engine rebuild project the car ran good so I think the distributor is fine, just that the plastic gear is looking old....yellowed and brownish looking......
Just go with the plastic again?
 Post subject: Yes...
PostPosted: Sun Sep 25, 2016 9:42 pm
Yes.
PostPosted: Mon Sep 26, 2016 3:43 am
What local Parts store in Pittsburgh Has a Bronze gear for the slant 6?
I bet it is listed as a wrong application?
If they order it in I would assume it would not fit.
I would be interested to see it compared to the Nylon one.
Best of luck,
PostPosted: Mon Sep 26, 2016 4:48 am
There is a bronze gear for the Ford inline 6 cylinder engines that works on the slant six. Rock Auto also lists it (or did). I asked the forum about them a year ago and was told not to over think the distributor gears. The plastic was recommended as the preferred choice for the slant six. I don't recall any of the reasons.
PostPosted: Mon Sep 26, 2016 5:13 am
Thanks all...will go plastic. The bronze gear is listed on advance auto's site as a fit.
PostPosted: Mon Sep 26, 2016 8:50 am
hmmm. Interesting.
There is hardly any load on that gear so plastic will be fine.
As long as it's not dry rotted etc.
PostPosted: Mon Sep 26, 2016 11:01 am
Just in case you needed additional info...
http://www.slantsix.org/forum/viewtopic.php?t=58786
PostPosted: Mon Sep 26, 2016 11:23 am
And it's not obvious how the new pinion gets installed. See this thread.
PostPosted: Mon Sep 26, 2016 12:38 pm
I did not know that about the distributor gear hole.
Good info.
thanks SlantSixDan
PostPosted: Tue Sep 27, 2016 7:59 am
I see that the "wrong hole placement" is listed for a particualr replacement number.....
I picked up Dorman 90450 HELP! Distributor Gear and am waiting for it....
Any chance it is "right" ?
Assuming its not, looks like you just reference the original gear hole location? Although how do I know IT is correct?
PostPosted: Tue Sep 27, 2016 10:16 am
You cannot use the predrilled hole in the plastic pinion, no matter what brand it is. You must follow the procedure in the other thread.
PostPosted: Tue Sep 27, 2016 1:43 pm
Should have asked this years ago...........
Why is there a predrilled hole if it's worthless?
PostPosted: Wed Sep 28, 2016 5:41 pm
Car Model: A couple slant six mopars and other mopars
In my opinion the pre drilled hole is to fool an uneducated mechanic, ie shade tree, into causing further damage to a perfectly good engine.
Shame on the manufacture.
If I remember correctly Slant Six Dan even contacted the manufacture about their faulty product. Or was it the distributor caps he did this with?
  • http://www.forabodiesonly.com/mopar/attachments/slant-six-dizzt-proper-set-up-3-jpg.184646/[/img]
PostPosted: Thu Sep 29, 2016 10:02 am
It was Echlin distributor caps, a long time ago.
PostPosted: Thu Oct 06, 2016 10:52 am
SO I got the new part and compared it.
The new parts hole is very slightly higher/lower than the original on the distributor. That said I cant say that the old one isnt a replacement done wrong.
So will follow the directions elsewhere about pushing the shaft all the way down with the washer and gear on it then locating the hole.
