It is currently Wed Nov 11, 2026 1:12 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Wed Sep 28, 2016 5:47 pm
Glad you found the issue.
I like Reed's idea.
'78 Volare 225
'67 Charger 318
PostPosted: Wed Sep 28, 2016 5:55 pm
Give up on the valve cover-shaped trinket and put on a real cover, with real baffles. Then the real grommet and the real PCV valve will fit and work correctly
Not mine, and it may not be the best, but that is not the question. Just wondering if the part number you listed for Dorman has changed. The obvious spare peg does not fit the round hole! :lol: :lol:
PostPosted: Thu Sep 29, 2016 1:46 am
Anyone played with Cerakote? Gun people use it.
http://www.cerakoteguncoatings.com/finishes/
PostPosted: Thu Sep 29, 2016 7:39 pm
I have used ceracoat. It's very durable stuff.
This block should only allow 225 characters instead of 255
PostPosted: Tue Oct 04, 2016 3:51 am
If you have the 1 1/4" hole in the valve cover I found a rubber grommet that has a built in baffle at Advance Auto. It is a Mr.Gasket Part #5425,. 2 PACK FOR $5. This baffle would give a little more seperation of the oil from the PCV valve.
PostPosted: Tue Oct 04, 2016 6:52 pm
I got a GM Olds PCV/ Breather looking doodad with the baffle. MP breather, oil that comes out gets wiped on the cheap chrome. :lol:
