It is currently Thu May 28, 2026 12:21 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Sun Oct 09, 2016 12:41 pm
Maybe not, Azlaw. Let's explore what you said in your first thread post. You "blew" the starter in your truck. Could you clarify what you mean by "blew" it?
Does it still turn over, but not engage the flywheel?
Roger
To be exact - the fender relay throws but the starter does nothing. No click, no grunt, no nothing.
I have the starter out now, looks nice and fresh - which is reasonable since its only 2 years old. The gear seems to not retract very well, we were having that problem in operation. This is definitely a direct drive unit, no gearing.
But... since this bellhousing could be anything, what is this business of "high-mount" vs "low-mount" starters?
H
1964 Dodge W200 Power Wagon
PostPosted: Sun Oct 09, 2016 4:59 pm
Car Model: '23 T-bucket
OK, might you have a volt/ohm meter, and/or know how to use one? I suggest you pull a voltage test at both sides of the new starter relay, and see if you're actually getting voltage to the starter.
Back to the volt/ohm meter. As long as it's out, try getting an ohm reading from the hot cable terminal to starter housing/ground, through the starter.
I strongly suspect these are a permanent magnet, DC motor with brushes. It could be that the brushes failed. (I've seen too many chinese motors with brushes, where the carbon material the brushes are made of are rather soft, and wear away rather quickly.)
Being as I have no direct experience with the low-mount, early direct drive starters, I'll have to defer to someone else for a good answer to that.
Roger
PostPosted: Sun Oct 09, 2016 9:10 pm
Had the unit over to the Auto Parts place on their super-whiz-bang test-o-meter. Looks like the brushes and/or bearings are toast, motor will not run at all.
H
PostPosted: Mon Oct 10, 2016 3:49 am
With shot brushes, there's no continuity through the windings, so no current flow, and no rotation.
There might be bearings, but I suspect it's got bushings, not true bearings.
I don't know if one can find quality brushes to swap out in it or not, only a decent automotive electrical guy could tell you that.
Roger
PostPosted: Tue Oct 11, 2016 7:45 pm
Man, I can't even get a Chinese rebuilt at this point from the auto-box stores. Gonna have to actually have the thing rebuilt by the electric shop.
A sign of the times, gentlemen...
H
PostPosted: Wed Oct 12, 2016 2:45 am
Why do you say that like it's a bad thing...?
PostPosted: Fri Oct 14, 2016 11:54 pm
It turned out to be a good thing, in fact. Turns out that "Pro-Amp" parts are a trade name for Tucson Alternator Exchange. So, the unit was one of their rebuilds - who knew? The nice people there took it in, and had it fixed in 2 hours. No charge. Love these folks!
The problem was the field wiring literally burned in half. No good theory on why, but they overhauled the unit, so hopefully we are good to go for awhile.
End of problem.
H
PostPosted: Sat Oct 15, 2016 4:21 am
Well, there ya go! :D And they're local to boot. Any chance they'll sell over the counter if you need one again?
Roger
