It is currently Tue Mar 04, 2025 1:41 pm
 Post subject: Distributor gasket?
PostPosted: Sat Oct 08, 2016 2:23 pm
For the distributer, the engine gasket kit gave us a gasket but it seems like it should be a o ring instead based on what the block looks like....
We had only the squared off o ring on the shaft when we pulled the distributor...
We don't have a new squared off, was gonna reuse for now....
The block looks like it needs a o ring...
And the gasket in the Victor reinz engine kit is a thick squared off gasket......worried it will have the distributor up too high...
Thpughts?
 Post subject: Nope...
PostPosted: Sat Oct 08, 2016 2:52 pm
That item is for something else, there should be a large round O ring that fits on the shaft that fits the bezel... that being said, there are lots of slants on the road without them....
PostPosted: Sat Oct 08, 2016 8:19 pm
Round-section O-ring is correct at that location. The engine will run fine without it, but you'll get less oil leakage/seepage with it.
PostPosted: Mon Oct 10, 2016 5:00 am
Thanks guys.
It seems that the Victor Reinz gasket kit my builder used has a bunch of gaskets that arent used on mine......and it doesnt have the big o ring at all.
Anyone know the size/dimensions of the proper o ring ? I assume I can get one at the hardware store....if I take the distributor with me....a bit of a pain.
Looking online and cant seem to find one to order...even rock auto.
PostPosted: Mon Oct 10, 2016 8:18 pm
I just did mine and had the same issue. I reused the old square one and for the round one, I went to harbor freight and bought a small box of assorted o rings for about 4 bucks. Tried a couple sizes until I found one that fit and didnt drip oil.
64 Val Signet 200 Vert
 Post subject: o-rings
PostPosted: Tue Oct 11, 2016 7:51 am
Go to www.mcmaster.com
they'll have any O-ring you can imagine and many you can't. I got mine there, sorry I didn't keep the part # in mind.
brian
https://tinyurl.com/yynpj4v2
 Post subject: I remembered...
PostPosted: Tue Oct 11, 2016 8:10 am
The big fat o-ring at the top is an R19, and the one (actually you can fit 3) on the shaft is a standard #33 o-ring you can buy at any hardware store.
brian
 Post subject: 3 or 1
PostPosted: Tue Oct 11, 2016 8:11 am
Clarification, you can fit 3 on the wide slot on the shaft like you have, some distributors have a narrow shaft that only holds a single o-ring.
b
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot], Semrush [Bot] and 44 guests
