It is currently Sun May 03, 2026 11:45 pm
 Post subject: WTF did I do wrong?!?
PostPosted: Fri Oct 21, 2016 5:02 pm
I am attempting to do a KH 4 piston swap and change the bushings. I installed the UCA's on what I thought was the correct sides, but the ball joint wasn't even close to the spindle. If I swap the UCA's to what I presume is the wrong sides, the ball joint can reach the spindle, but it's at a CRAZY angle. Where did I go wrong?
If I was half as smart as I thought I was 30 years ago, I'd be twice as smart as I am now
PostPosted: Fri Oct 21, 2016 6:21 pm
got a picture ?
 Post subject: bumper
PostPosted: Fri Oct 21, 2016 6:35 pm
the rubber bumper and stop on the UCA should tell you if you have them on the correct side, i.e. the rubber bumper should be registered with a stop on the UCA.
brian
https://tinyurl.com/yynpj4v2
PostPosted: Fri Oct 21, 2016 7:53 pm
You must unload the torsion bar and lift the lower control arm.
PostPosted: Sat Oct 22, 2016 9:16 am
I will post pics as soon as I can, weather cooperation needed.
The torsion bars are out, so no load there
PostPosted: Sat Oct 22, 2016 10:07 am
Does it matter what side the spindles are on?
ski
PostPosted: Sat Oct 22, 2016 10:36 am
They can only go on one side
