It is currently Sat Jun 13, 2026 4:01 pm
PostPosted: Thu Oct 27, 2016 2:57 pm
Car Model: 1964 Plymouth Valiant 225, 1977 Dodge D100 225
Hey, everyone. I've seen on here and other places that the heater hose fitting for the cylinder head is 5/8" for the hose and 3/8NPT for the part that goes into the cylinder head. I have an drool tube cylinder head of unknown vintage and it definitely does not fit. I bought a steel one and it didn't fit. Then I got a brass one from another company just to make sure I didn't get the wrong fitting. Same thing.
I used calipers and I get 0.4845" which is nowhere near 1/4 or 1/8 NPT. A half inch bolt kind of fits in there ok.
Don't see it coming up on any car part searches. Has anyone else come across this? Any advice would be appreciated. Thanks!
Photo for reference courtesy of Eatkinson.
Image[/img]
Chuck and the Flying Valiant
PostPosted: Thu Oct 27, 2016 3:55 pm
Maybe 1/4
http://machiningproducts.com/html/NPT-T ... sions.html
PostPosted: Thu Oct 27, 2016 4:03 pm
pretty sure all of the ones I have seen are 3/8" NPT
 Post subject: agreed
PostPosted: Thu Oct 27, 2016 4:09 pm
3/8" NPT
https://tinyurl.com/yynpj4v2
PostPosted: Fri Oct 28, 2016 8:52 am
Okay. Here's what I bought, in steel and brass. Neither fit:
http://www.ebay.com/itm/221778485288?_t ... EBIDX%3AIT
https://www.amazon.com/Anderson-Metals- ... 5%2F8&th=1
Just for giggles, I tried to screw in a fitting from my air hose (which is a 3/8 NPT) and it fit fine. It doesn't make any sense, unless both separate vendors sent me the same wrong part. I don't get it. Of course, my town doesn't have any company that sells these sort of fittings in-store, so what do I do? I can't keep flushing $10 down the drain to test these parts out, then pay $5 bucks to send them back.
PostPosted: Fri Oct 28, 2016 10:11 am
Your 3/8" air hose doesn't use 3/8" NPT fittings. That's 1/4 NPT.
PostPosted: Fri Oct 28, 2016 10:59 am
Advance Auto? They should have a Dorman part number that would work. Or Auto Zone....etc.
Buy a 3/8 pipe thread nipple at the local hardware store for less than a buck and try it. Then you will know for sure what you need.
Rick
Advance Auto parts - Dorman # 56152 5/8" hose X 3/8" NPT X 1 1/2" long
 Post subject: thread size
PostPosted: Fri Oct 28, 2016 11:31 am
You said your diameter measurement was 0.4845" I assume you measured at the base of the threads nearer the hole - NPT are tapered threads.
3/8 NPT threads at the start are about 0.61" diameter but the pipe itself is 0.68" Same numbers for 1/4" NPT are 0.48" and 0.54", so it based on your measurement it sounds like you have 1/4" NPT.
Brian
PostPosted: Fri Oct 28, 2016 2:00 pm
If you have 1/4 NPT to the heater hose, I don't think that size is right. You will have a restriction in the hose to the heater core. If it turns out to be 1/4" I would probably just drill it out and tap it to 3/8" and then all those nipples you bought will work just fine! :lol: :lol:
Was this head on a passenger car/truck? Just trying to figure out why it is so small.
PostPosted: Fri Oct 28, 2016 3:24 pm
Could there be a 3/8 to 1/4 reducer bushing in the head?
 Post subject: adapter
PostPosted: Fri Oct 28, 2016 4:47 pm
Could be there's an adapter in there...
I was thinking the same thing as Rick, even if it is 1/4" NPT, just drill and tap it to 3/8" NPT and your new fittings will work fine. I've never seen other than 3/8 fitting there. Use the steel one, not the brass one....
brian
