It is currently Tue Nov 17, 2026 6:54 am
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
 Post subject: Slant six throttle cable
PostPosted: Wed Oct 26, 2016 7:45 pm
Car Model: 1968 Plymouth Barracuda slant 6 super six 4 speed.
Hey dudes and dudets, got a 68 barracuda slant 69 with a clifford intake and holley 2 barrel set up. What seems to be the problem is that the throttle cable I have now is of a small block. It's too short (from Oakland) and wondering for this conversion, if I need a slant 6 throttle cable or a new lokar throttle cable.
I'm human and I do things for the universe.
PostPosted: Thu Oct 27, 2016 7:51 am
I would recommend just going to a bicycle store and using a mountain brake throttle cable. You can get them in any length.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sat Oct 29, 2016 4:39 am
Quit your mocking.
Whoa. Is that a super 6 conversion for the Holley 2BBL? Is that a Holley 2280 by chance? You need to be more specific here Magnum. If this is the case, the original throttle cable for the one barrels carbs (at least on 72' +) is that they're (if I recall 22" long.) The throttle cables for the super six are the same ones used for the 318ci V8 which are 19.5" long. Hope this helps.
exoJjL
PostPosted: Sat Oct 29, 2016 6:11 am
Quit your mocking.
Now there's an insult based on ignorance......
Matt is right...and you lack credibility.
 Post subject: Option #2...
PostPosted: Sat Oct 29, 2016 10:25 am
Depending on the throttle plate orientation (especially if it is bore parallel to the head/engine), you can get a Spectre throttle bracket in the aftermarket aisle of your autoparts store , then use a long throttle cable from a late 80-90 Dodge mini-van, or from an 80's Aries/Reliant if you are hunting in junkyards.... (This is what I do on my hyperpak intakes, and worked even on a super six manifold mounting a Holley 2305 carb...)
FYI.
PostPosted: Sun Oct 30, 2016 6:55 am
Quit your mocking.
t
As you do also lack credibility if you are also unable to correct my "ignorance" yet it's funny how it's an insult to call out arrogant [EDIT: foul language removed by Rob Simmons] (like yourself) who think they know everything without giving out the information (or even reading the threads information title.)
exoJjL
 Post subject: Slantsix throttle cable.
PostPosted: Sun Oct 30, 2016 7:47 am
All right.
Matt is correct. You can get a throttle ( or any similar cable) made up at a bike shop in any length with any ends. Its inexpensive and available.
....and , yes we all read the thread title...Matt gave the information...which I backed up.
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
