It is currently Tue Nov 17, 2026 8:17 am
PostPosted: Tue Nov 01, 2016 7:35 am
I just found out that I bought a Super 6 Carter BBD for a manual trans but I have a automatic. What are the difference between those 2 setups? Are there only different jets? Or is the metering rods also different? I bought the BBD because my Super 6 2280 running lean and I cant find jets for the 2280. Don't want to run lean especially when I'm soon going to put my Slant with higher comp and RV10 cam. BBD have new jets to buy and I have better luck tuning them so that's why I bought a new one.
PostPosted: Tue Nov 01, 2016 9:44 am
2280 jets are available in a wide range of sizes. Not at your friendly local auto parts store; you'll have to order them, but that's still your easier tune path.
PostPosted: Tue Nov 01, 2016 10:20 am
.....so as part of my never ending learning curve about the slant six.....and not wanting to hijack the thread but I have to ask...
There is a difference between carbs for an automatic versus standard?
Dan, the one I got from Mike....do you know if it one or the other? It has the "dashpot" as you called it...so does that mean its a standard carb?
Why would there be a major difference??
PostPosted: Tue Nov 01, 2016 12:03 pm
There are often calibration differences and sometimes accessory differences (dashpot/no-dashpot).
Different calibration for optimal driveability with the different demands placed on the engine with the two types of transmission. Example: Cruising along at 45 mph, yank your foot off the accelerator. In an automatic car, the engine more or less freewheels. In a manual car, the engine is motorised by the wheels.
PostPosted: Tue Nov 01, 2016 12:26 pm
Where can I find jets to the 2280 then? I have not found any online.
PostPosted: Tue Nov 01, 2016 12:51 pm
Walker makes them. http://www.walkerproducts.com/catalogs/ I think probably it's their 120-6 series, but probably best call them to find out for sure. You might also check with CarbsOnly http://carbsonly.com/ .
 Post subject: Yep...
PostPosted: Tue Nov 01, 2016 5:39 pm
Causing the throttle plates to close, the vacc gauge to max out, the carb to go to the idle circuit...and if not calibrated properly to be a little rich or have the dashpot keep the throttle plates open a bit to get it into the transition or mains until things return to 'normal', the mix leans out the exhaust sounds liek you are shooting ducks and if done enough times your spark plugs, pistons and exhaust valves and seats will suffer....
Of the manual tranny driver shifts to0 early lugging the car along at low rpm in a high gear imposing a load outside the power band...
