It is currently Tue Nov 17, 2026 12:53 pm
 Post subject: Spring retainers
PostPosted: Wed Nov 02, 2016 7:30 pm
Car Model: 1965 A100 pickup
I'm in the middle of my rebuild and need some info. I bought oversized valves from SI valves and need retainers and locks. SI says they don't carry them. The intake valves are a 2 groove lock and the exhaust are 4 grooves. Can anyone tell me where to get retainers and locks for these valves? Thanks, Doc.
PostPosted: Fri Nov 04, 2016 9:09 am
Those valves should use stock style valve locks. Comp Cams has Chrysler multi-groove locks. Ignore the picture. https://www.summitracing.com/parts/cca-606-16/overview/
Retainers are based on the spring dimensions, but these are correct for a 340 type spring (large OD single spring with flat damper): https://www.summitracing.com/parts/cca-744-12
If you have smaller springs or certain dual springs you'll need different retainers.
 Post subject: x2
PostPosted: Fri Nov 04, 2016 5:15 pm
Yes the SI valves I have I reused the locks from the stock valves.
PostPosted: Fri Nov 04, 2016 6:29 pm
Thanks for the info guys.
