It is currently Thu May 28, 2026 10:22 am
Post new topic  Reply to topic  [ 244 posts ]  Go to page Previous 1 2 3 4 517 Next
PostPosted: Tue Nov 15, 2016 11:20 am
You need to adjust the reluctor gap in the distributor. There should be something like a .008-.012 gap between the pickup and the reluctor. Looks like you may even need a new reluctor.
PostPosted: Tue Nov 15, 2016 11:27 am
I'll try gaping it next.
That sounds like something that has to be ordered too!
ARRGGGGGG.......
PostPosted: Tue Nov 15, 2016 12:08 pm
Gapped it - no change...
Took distributor up and moved rotor back and it fired and is running...
A little roughly though...
Ordered new wires from local auto parts store will be in around 5 tonight...
Will be getting new fuel filter too...
"I may be slow, but at least I'm not very fast!"
'69 A108 - 225, 727, 3.55, MSD6AL, a.k.a.-the brick
PostPosted: Tue Nov 15, 2016 12:36 pm
Tried driving it again and it is acting the same way.
I put it in gear and it runs rough and when I give it gas it is acting like a tank chugging and chuffing...
Get's worse if I try to go faster or give it more fuel...
PostPosted: Tue Nov 15, 2016 12:38 pm
I just noticed that as of yesterday, I have been on this site for 14 years!
Wow!
and I'm still a broke ass son of a beeoooch...
with a broke ass van now...
600 miles away from home...
hopefully that stray bullet I keep hoping for will find me soon!!!
PostPosted: Tue Nov 15, 2016 1:09 pm
What do the plugs look like?
PostPosted: Tue Nov 15, 2016 1:17 pm
Plugs, cap and rotor are brand new as of about 6:30 last night...
Wires will be brand new as of about 6:30 tonight!
lol
PostPosted: Tue Nov 15, 2016 1:24 pm
I am in Orange, CA for those of you unaware...
Came down to visit my sister and go to a van show in San Diego on Saturday...
Everything went beautifully, the van has been running great...
Get up and go wash the thing and get my hair cut and it takes a huge dump on me...
It is probably something simple - but at this point it is anything but simple...
Wish I could remember what I already posted, but, as to washing it - I did spray underneath, but made sure no pressure and very little water went up to the distributor or into the doghouse... the distributor was dry when I got home and checked it - as was the doghouse. I looked for loose wires that may have gotten blown off and there is nothing resembling that! lol
Carburation and fuel - next chapter in the continuing dufus drama of the WhaleMstr... movie rights for sale... inquire within...
 Post subject: wash....
PostPosted: Tue Nov 15, 2016 2:50 pm
Any chance water got into the fuel tank? How is the seal around the gas cap? Dump a bunch of methanol (dry gas) or ethanol (200 proof) in there and try again....
brian
https://tinyurl.com/yynpj4v2
PostPosted: Tue Nov 15, 2016 2:58 pm
Chances are slim, but not impossible at this point! LOL
New fuel filter, some gas additive, and new plug wires as soon as my sister gets home and takes me over to the store... plus a new air cleaner for the carb - just for $#!+ and giggles...
If this doesn't do it - I'm gonna drink until I don't give a crap and wake up tomorrow and worry about it then...
Along side a headache...
That should make tomorrow fun huh???
AARRGGGGGGG.....
PostPosted: Tue Nov 15, 2016 3:44 pm
Water get on the MSD box? Water get into the MSD box conectors? Grounds clean and tight?
 Post subject: hmmm....
PostPosted: Tue Nov 15, 2016 3:59 pm
Whalemster, I said put the ethanol in the tank, not in you.... :P
Brian
PostPosted: Tue Nov 15, 2016 4:01 pm
The MSD box is inside the van - bolted to the engine compartment so it is out of weather and heat. The connectors and wires were coated with oil and some still are because I did not shoot water on them. I suppose I need to check all of them now too...
If none of this works tonight, I am onto a compression check in the morning...
I still need to re-adjust the Holley though, I know it is very rich...
What is the proper way to set one to start?
2 3/4 turns out from closed or what?
I need to check all of that...
This thing has always been a pain in the butt...
I have the carb you sent me someplace still Reed - just never went any further with dealing with it - because this one was working...
PostPosted: Tue Nov 15, 2016 4:10 pm
Brian! LOL
Us old guys need lubrication every now and then too ya know!!!
 Post subject: water
PostPosted: Tue Nov 15, 2016 4:15 pm
I think you see what Reed and I are getting at though, it seems more than a coincidence that this started after you washed it.
Usually, not always, but usually there is a suspect right in front of you.
brian
P.S. I understand, I used to be a beer drinker, now I like red wine...neither of those will help in your gas tank anyway, so go ahead...but if you're planning to drink grain alcohol, better to just dump it into the gas tank.
