It is currently Tue Nov 17, 2026 9:20 pm
 Post subject: ignition problem
PostPosted: Wed Nov 16, 2016 9:35 am
added a new pick up coil in distributor and ignition wiring harness. so now I can start the engine but as soon as I let off on the key it shuts down. Whats my wiring problem ?
PostPosted: Wed Nov 16, 2016 10:00 am
Ballast resistor failed is the usual culprit with those symptoms.
