It is currently Tue Nov 17, 2026 9:14 pm
PostPosted: Wed Nov 16, 2016 10:09 am
I have just picked up a 225 and took the oil pan off and noticed oil holes in rods are the wrong way it is a very giod running engine and looks ro be very recently rebuilt should i remive the head and put the rods in they way they are suposed to be ir just leave it. I unerstand the old aluminum engine had them in this way. Just was wondering if the cam would fail if i leave it. The engine will be used as a daily driver no hard use or rpm.
Thanks mike
PostPosted: Wed Nov 16, 2016 3:09 pm
Maybe backwards, maybe not. See here.
PostPosted: Wed Nov 16, 2016 3:28 pm
The enhine i have is a 1976 forged crank engine so by what that article says they would likely be in backwards. Do you think i should just leave it alone or do you think it would cause problems
PostPosted: Wed Nov 16, 2016 4:34 pm
Me, I'd want to fix it.
PostPosted: Wed Nov 16, 2016 5:07 pm
Ok thanks dan it wod likely be on my mind the whole time so might aswell pull it apart and fixed it maybe there are other mistakes in it also
PostPosted: Thu Nov 17, 2016 3:20 am
What are your uses for the engine? Does it run well and not smoke or leak? Unless used under extreme conditions, I would probably leave it alone, since any disassembly will risk introducing new faults. If you have the time and inclination, however, then go for it.
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
