It is currently Tue Nov 17, 2026 10:32 pm
 Post subject: Overheating Slant
PostPosted: Mon Nov 21, 2016 1:02 am
Reasons for overheating?
Radiator looks ok, I have reversed flushed and there was a little muck.
Thermo looks ok too, the correct temperature rating (I think) 180F.
Hoses seem ok.
Water pump works ok.
Engine block - not sure. It has been flushed and some much came out, but not much.
Ideas and advice appreciated.
Thanks.
 Post subject: Is it...
PostPosted: Mon Nov 21, 2016 5:40 am
Does it open is the better question, pull the stat and dump it into a boiling pot of water... let sit a for a bit and see if it opens, if not time for a new one... Had that happen on a Stant stat after 14 months of daily driving, it just would barely open and stick killling the water flow...
