It is currently Wed Nov 18, 2026 12:01 am
PostPosted: Mon Nov 21, 2016 11:09 am
For a slant six to be mounted on an engine stand.
Anyone know the size?
'78 Volare 225
'67 Charger 318
PostPosted: Mon Nov 21, 2016 12:25 pm
3/8 UNC
 Post subject: Eng stand
PostPosted: Mon Nov 21, 2016 12:51 pm
Use caution as motor is extreamly unbalanced I ended up with the 2 legged stand with support rods down to stand legs
I would recommend a few buddies there when you want to rotate the motor
1963 Plymouth Valiant Wagon
 Post subject: bolts
PostPosted: Mon Nov 21, 2016 1:01 pm
I use grade 8 bolts and those even get bent some. I use a Harbor Freight engine stand, it seems plenty strong enough. I did use a longer pipe handle to make rotating the engine easier for one person, my handle is about 3 feet long (the one that comes with it is only maybe 18" long or so,way too short for much leverage).
Brian
https://tinyurl.com/yynpj4v2
 Post subject: Yep...
PostPosted: Mon Nov 21, 2016 5:53 pm
Size will be dependent on what holes in the block you use... I typically set the prong up to use 2 of the upper bolt holes into the block, and the outboard arms through the lower holes/ears on the tombstone, which would require a longer bolt with nuts and washers at both ends...you can adjust the center of the prong to have a better center and balance for the engine... at least until the head and manifold are on it...
You should use a washer at the head of the bolts and they will take the load of the engine better, I have yet to bend a grade bolt...
I have 3 harbor freight engine stands that I bought back in the 90's and they originally held mid-70's 400 big blocks....make sure to use a 4 wheel stand not the 3 wheel...
Users browsing this forum: Amazon [Bot], Google [Bot] and 7 guests
