It is currently Mon May 18, 2026 9:52 pm
 Post subject: torque converter
PostPosted: Thu Dec 01, 2016 4:45 pm
They changed spline count from 68 onward on the A904 input shaft from 18 spline to 27 spline, is that correct? I can't seem to find anyone who sells the older '67 torque converter.
Brian
https://tinyurl.com/yynpj4v2
PostPosted: Thu Dec 01, 2016 6:46 pm
Call Midwest converter. I have a spare stock one if you need one.
 Post subject: thanks Lou...
PostPosted: Thu Dec 01, 2016 7:10 pm
I'll let you know, I'm just looking for stock. I was confused as some of the autopart sites say they fit a '67, but I'm pretty sure they're 27 spline.
B
PostPosted: Fri Dec 02, 2016 4:38 am
I thought that 66 was the last year for the small spline/input converter? Probably I am remembering incorrectly. Anyway, I both late (big hub, big spline) and early (small hub, small spline) stock converters and can let one or more go. Again, I can't remember if there were small hub, big spline versions for a year or two...
PostPosted: Fri Dec 02, 2016 5:16 am
For a stock or near stock application, Dacco converters has several units.
http://www.daccoinc.com/catalogs
Page 175
Their part number is 403
For a 67 older engine and 68 newer trans part number 762S
For a 68 newer engine and trans part number 762
For a 68 newer engine and 67 older trans part number 762X
I think if you call them, it is possible to special order a limited higher stall speed over stock.
PostPosted: Fri Dec 02, 2016 9:35 am
That's for V8s. For \6s the last year for it was '67.
Fortunately not -- it's a clean before/after break: small hub and spline til '67, then big hub and spline starting '68.
PostPosted: Fri Dec 02, 2016 10:34 am
Great. Thanks, Dan.
Let me know if you want a used stock converter. $10+ship...
 Post subject: thanks all
PostPosted: Fri Dec 02, 2016 3:25 pm
Lou, I'll let you know.
Brian
PostPosted: Fri Dec 09, 2016 4:19 pm
I found a torque converter that is supposedly "new in the box"; it's an aftermarket unit. It looks unused, still has stickers from manufacturer on it.
I noticed when I shake the unit I hear stuff clunking around in there. Is that normal or should I not hear that?
I can provide a video if that helps.
Brian
 Post subject: more info
PostPosted: Fri Dec 09, 2016 4:21 pm
Its an A904 converter for a '67 dart, so 18 spline, non-lockup. b
PostPosted: Fri Dec 09, 2016 6:12 pm
If it's never had fluid it it it will probably clunk.
 Post subject: clunk
PostPosted: Sat Dec 10, 2016 8:45 am
Thanks Dennis. b
