It is currently Fri Nov 20, 2026 4:32 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Thu Dec 22, 2016 8:53 am
There are some cam cores with a thicker shaft...
I got one from Oregon Cam Grinding for the Bonneville engine. Imagine the shaft being thick enough that it nearly comes to the base circle of the lobes. I was told by OCG that the smaller shaft was done for rod clearance, but it think that's a mistake. So if you want a really heavy, strong cam, buy the "170" cam.
I have also seen these "thick shaft" cams and agree that I tend to find them in the early engines... both 170s & 225s
I think Chrysler went to the smaller shaft design simply for cost savings / weight reduction.
These kinds of changes usually come from the supplier(s) who are constantly getting pushed for cost reductions.
Chrysler asks for cheaper parts as they ramp-up production and the supply base says OK... as long as you change xxx, in this case, that change was taking some cast iron out of the cam cores.
Just my 2 cents...
PostPosted: Thu Dec 22, 2016 9:27 am
Car Model: Toad Wagon
Just my 2 cents...
Though limited to 225s, this's my observation as well.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Thu Dec 22, 2016 9:29 am
That makes a lot more sense. Thanks, all.
Users browsing this forum: Google [Bot] and 8 guests
