It is currently Mon Nov 23, 2026 9:03 pm
 Post subject: Starter Relay ?
PostPosted: Tue Dec 27, 2016 9:48 am
85 Dodge D100, Manual transmission
I think I have a bad starter relay but need some help. I am "slow" electrically!
Truck has a bad ignition switch and it has a push button to start for the time being. Relay has red, power from battery- check. It has the brown from the relay to the starter- Check. It has a green wire that goes to a good ground- check. The original orange wire from the ignition switch has been replaced with the new wire from the push button. With ignition switch turned on, and pushing the button I have power to the relay but the starter does not turn. So is my relay bad? It looks pretty simple, but I just wanted to make sure I am not doing something stupid!
I can jump across the starter wires and it engages, so it is ok.
Thanks!
PostPosted: Tue Dec 27, 2016 1:13 pm
I am not sure what the orange wire is from the ign switch. Try running a wire directly from the batt to the pushbutton and see if it cranks. Then, you should be able to use any known good wire/source that has 12V with ign switch in "run" position.
I don't understand if you are getting power to the starter relay but the starter does not turn. If that wire is hot, then it should turn, as you said that you can jump from main starter terminal to relay terminal and it turns. Is that what you mean?
PostPosted: Tue Dec 27, 2016 1:47 pm
Make sure the truck's in Neutral. Use a screwdriver or similar to connect the two large terminals on the starter relay. If the starter activates, replace your starter relay.
PostPosted: Tue Dec 27, 2016 2:48 pm
Orange wire is the 12V from the switch to activate the relay. Green is the ground.
I found the issue after I posted. I took the known good relay off my truck and it still would not work. So I figured since the 12V is coming from the switch to trigger the relay (orange) it must be in the ground (green wire), and it was.
But here is what is a little funny(not really). I had replaced the end of the green wire since it was messed up with a new piece about 4 inches long. When I stripped the new wire I did not notice that it had an almost clear inner sheath for lack of a better word. So I stripped the outer coating of the wire but when I crimped it on I had no contact with the actual wire, just that inner sheath. This could have been avoided with better eye sight and by soldering the wires together!!
Don't ask me where the wire came from or what it is for. It came out of a bucket of loose wire ends I had laying around.
Thanks for your help, guys.
PostPosted: Tue Dec 27, 2016 3:42 pm
Car Model: '23 T-bucket
I'd have to question the wire color from the relay to the starter.....brown? Heavier cable, right?
You sure it isn't a heat-altered red?
Roger
 Post subject: Lol...
PostPosted: Tue Dec 27, 2016 4:12 pm
Double check to make sure that the 'ground', is not a finicky clutch safety switch or neutral safety switch or connection either... unless you modified that prong to be like the early-mid-60's cars and wired the prong to the relay mounting screw (direct to ground)... eliminating it (and hope you don't forget when starting the vehicle... LOL)
PostPosted: Tue Dec 27, 2016 4:42 pm
Brown is what all 3 of our trucks have and what the FSM calls out. About a #12 wire.
PostPosted: Wed Dec 28, 2016 6:30 am
OK, Rick. I thought you might have been talking about the primary power cable for the direct starter power.
Roger
PostPosted: Wed Dec 28, 2016 9:59 am
Oooh. No that one is hooked up too. :lol: :lol:
PostPosted: Wed Jan 11, 2017 2:50 am
Relay may be ok. Check the earth to the body.
PostPosted: Wed Jan 11, 2017 1:44 pm
Funny, I was sure I posted what I found!
It was a ground issue with the green wire. All fixed!
