It is currently Thu Nov 19, 2026 11:52 pm
PostPosted: Fri Jan 06, 2017 2:53 am
If I replace my 4 blade radiator fan with a 5, 6, or 7 blade fan will I get more engine cooling?
I have a slant 6 motor.
PostPosted: Fri Jan 06, 2017 6:58 am
A fan shroud will help the most. I don't have a shroud. I installed a 7 blade or maybe it was a 6. My 64 D100 is definitely cooler. I intentionally pushed it to 65-70mph and stayed cooler than it ever has.
I'm going to attempt to fix this project and not make it any worse.
PostPosted: Fri Jan 06, 2017 8:55 am
Car Model: Toad Wagon
Short answer is yes, it will have a positive effect, at low speed.
Whether it'll be enough for your purpose is the subsequent question.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Fri Jan 06, 2017 3:32 pm
Question is too vague to get a helpful answer. Article to read is here (eventually you'll get to Part 5, which covers fans)
