It is currently Thu May 21, 2026 2:11 pm
 Post subject: Head reassembly
PostPosted: Fri Jan 06, 2017 2:47 pm
Ok guru's I need a hand.
When reassembling a slant cylinder head is there any trick, or has anyone create a fixture to hold the head at a good angle so you can access it with a valve spring compressor (c-clamp style)? I am struggling, and figure there has to be a better way/trick to it
PostPosted: Fri Jan 06, 2017 4:43 pm
Car Model: 62 Valiant
I haven't tried a slant head yet, but at the shop i worked at had a few home made stands for heads. they were made from old pushrods and pieces of angle iron. they looked sorta like this:
they had more angle on the posts and they had a washer to hold the head up at height
PostPosted: Fri Jan 06, 2017 6:14 pm
This is what I did with some scrap wood. Works great for removing valve springs.
 Post subject: x2
PostPosted: Fri Jan 06, 2017 7:23 pm
That's what I use on the bench when putting everything together!
:wink:
PostPosted: Sat Jan 07, 2017 2:57 am
I have a few home-made stands but to be honest, many times I just stand the head on it's end, to remove / install the valve springs.
( there are a couple of machined flats on the back-end so the head stands-up straight when on a hard & flat surface)
PostPosted: Sat Jan 07, 2017 10:54 am
Car Model: Toad Wagon
Same thing with the 2x4s, but I just use'em loose, as cribbing.
I keep a supply of'em, for a variety of cribbing uses.
Sex, drags, and rock & roll.
Dick, 225% crazy.
 Post subject: Thanks
PostPosted: Mon Jan 09, 2017 5:18 am
I was becoming frustrated, but have tried standing it on end, and it seems to be the handiest. Thanks guys
Users browsing this forum: Bing [Bot] and 5 guests
