It is currently Sat Mar 01, 2025 6:51 am
 Post subject: Air Cleaner ?
PostPosted: Mon Jan 09, 2017 11:00 pm
Hi Guys ,
would like to know is this air cleaner fix on carter BBD 2 bbl carb?
if yes any idea how to do that?
which car air cleaner it is?
Shahab Hanif Khan
Plymouth Duster 1975, 225 CID
PostPosted: Tue Jan 10, 2017 8:25 am
It looks like a 4 barrel air cleaner, so it would not fit a 2 barrel. I have no idea of what it came from
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Tue Jan 10, 2017 9:07 am
Can you show us the part of the air cleaner that attaches to the carburetor? I am not seeing how that air cleaner will attach to a carburetor, and it is the size of the opening for the carburetor that matters.
If it is an air cleaner for a four barrel carburetor, you can buy adapters to put a four barrel air cleaner on a two barrel carburetor, provided you have enough clearance under the hood.
PostPosted: Tue Jan 10, 2017 9:30 am
Hood clearance is the real issue. That's a HUGE air cleaner housing!
