It is currently Thu Aug 13, 2026 5:23 pm
Post new topic  Reply to topic  [ 54 posts ]  Go to page 1 2 3 4 Next
 Post subject: NP 435 clutch question
PostPosted: Fri Jan 06, 2017 6:16 pm
Just got the engine back in Andrews truck and it runs very well. Drove it down the road for a test run and the engine is fine, but while we were driving it around the main spring in the clutch broke ( Diaphragm type PP) and it will need replaced. We looked at the clutch while it was out and it looked good so we decided to just leave it in. Bad decision, now the motor has to come back out. With it being a 4X4 it is easier to pull the motor.
Problem now is where to get a clutch? Advance - none available, Auto Zone - none available, Rock Auto none available!! Am I losing my mind. They built 27 million of the these trucks with the 11" clutch and NP435 transmission and I can't buy a clutch and PP! :cry: Well I am guessing someone on here has purchased one, and will help me out. Thanks for letting me vent!
Are the V8 trucks with the 11" clutch the same as the slant 6?
Thanks to all.
 Post subject: Yes...
PostPosted: Fri Jan 06, 2017 7:11 pm
If it's the late 23 spline late NP435, then your interchange is a late Big Block V-8 11" clutch... (the test clutch in my car is a LUK diaphragm kit for a 1971 Dodge Truck with a 383 or a 383-2V manual transmission Dodge Car #05-016.... eventually if this works then I can swap to a race style diaphragm clutch )...
I had to order and wait 2 days to get the kit from a local vendor (not Autozone)
Small block clutches will not work since they are 10 1/2" not the true 11", and you have to watch other big block combinations (like 426 and 440) as they aren't quite right for what you are asking....
PostPosted: Fri Jan 06, 2017 7:58 pm
This should be what you need.
http://www.autozone.com/drivetrain/clut ... ckfit=true
1976 Feather Duster /6 4sp
1984 W100 318 727 np241
1972 'Cuda 340 4sp
1985 D250 360 46RH
PostPosted: Sat Jan 07, 2017 5:09 am
I'm not sure it was a 23 spline or a 10 spline Ill have to go look and see if I can look up from the bottom with the clutch depressed.
Thanks for the AutoZone help!
 Post subject: What year is it?
PostPosted: Sat Jan 07, 2017 1:40 pm
10 spline should only exist in the 60's... if the truck is original and 70's-80's it will be 23 spline.
PostPosted: Sat Jan 07, 2017 4:48 pm
Yep, I was able to get a small peak up between the broken diaphragm fingers and could see the fine spline.
Thanks for the info.
Rick
PostPosted: Sun Jan 08, 2017 1:00 pm
The same clutch for that truck for all v8 and slant six the six only usesdifferent flywheel
 Post subject: Errr.... no...
PostPosted: Sun Jan 08, 2017 3:08 pm
The same clutch for that truck for all v8 and slant six the six only uses different flywheel
This late slant six flywheel is set for the true 11" clutch, same as big block V-8 in certain applications (not Hemi or 440 six pack), it will not use the 9 1/2" 273 clutch, nor the small block V-8 10 1/2" clutch the 318/340/360/3.9/4.7/5.2/5.9).
That being said, some of the early 60's truck applications with the early bellhousing and some slant six industrial applications using this style are drilled for dual patterns that might allow for use of the small block clutch.
PostPosted: Mon Jan 16, 2017 5:08 am
More help please. Andrew ordered a clutch kit from Summit because he needed some other things from there. He got kit MU 5505-1B. We pulled the motor this morning and this clutch is not correct. It is an 11" 23 spline but the original pressure plate in the truck is recessed into the flywheel almost 1" and the new one is not. It also is the wrong bolt pattern.
He will call Summit to return this one but I don't know if they will have what we need.
The one from Auto Zone above may be correct but I can't see if it is recessed or not. Would you happen to know?? When I type in the trucks info on the Auto Zone web site it comes back as not fitting. When I ask what will fit it comes back with the 10" HD clucth which I know is not correct.
I went back to their site and it is the same number as what we got from Summit. So that one is not correct either!
Having trouble understanding why they don't list a clutch for these trucks when they built millions of them??? :? :?
Help appreciated greatly.
Rick
PostPosted: Mon Jan 16, 2017 8:51 am
Seeing anything other than a flat flywheel behind a slant is news to me! It might be easier to keep the clutch kit you have and find a flat flywheel.
PostPosted: Mon Jan 16, 2017 9:26 am
Has anyone else ever seen this style before? I am assuming it is Factory but that may be a bad assumption. Anyway, I still am in need of a clutch.
OK, in the Factory service manuals that I have it lists the Pressure plate as #1649 (Borg & Beck). And the clutch disc is # 14017. Any way to cross that over to something?
Does anyone have a flywheel setting around? 11"? Flat?
Rick
PS. FSM is no help on the flywheel at all. No pictures that I can find.
PostPosted: Mon Jan 16, 2017 2:45 pm
I have never seen a flywheel like the one in the picture. Mine is flat like all other flywheels that I have seen.
First count the teeth on the starter ring. The 11" truck clutch flywheel should have 143 teeth, The 10 1/2" and 11" scalloped clutch flywheel should have 130 teeth, the 9 1/2" and 10" truck flywheel should have 123 teeth.
1972 'Cuda 340 4sp
1985 D250 360 46RH
PostPosted: Mon Jan 16, 2017 2:47 pm
Also let's get this figured out before you return the clutch. That may end up being the one you want to use.
1972 'Cuda 340 4sp
1985 D250 360 46RH
PostPosted: Mon Jan 16, 2017 4:19 pm
It is definitely 11" I measured it myself. Didn't count the teeth, and it is setting on some blocks on the floor. If I have to count the teeth I can but I'd rather not hook it back up to the crane and count them if I don't have to.
Rick
PostPosted: Mon Jan 16, 2017 5:25 pm
The reason I ask about the tooth count is because if you can't find a matching clutch, you will have to get a different flywheel. Since the starter bolts to the bellhousing, you will have to have the proper flywheel to line up the starter.
Maybe someone has some info on a replacement for the clutch you have.
1972 'Cuda 340 4sp
1985 D250 360 46RH
