It is currently Fri Nov 20, 2026 8:52 pm
 Post subject: 170 slant to 904 lockup
PostPosted: Thu Jan 26, 2017 7:46 pm
Newby so go easy. I've got myself painted into a corner trying to
mate a 170 motor to a 904 lockup. Can anyone advise options and
best solution ? I've searched but can't seem to find this addressed
on the site.
PostPosted: Thu Jan 26, 2017 8:32 pm
what year 170?
PostPosted: Fri Jan 27, 2017 3:28 am
Welcome to the site
I'm assuming you have an early 170 (1967 or older), which has the small(er) pilot hole in the crank. Normally a special converter is used when using a later trans (1968 or newer). I don't know for sure, but I don't think they can build a lockup converter with the small pilot nub. You can call Dacco transmission parts at 800-443-2226. I know they make the special converter for the non lockup, so they will know what you are talking about, and can tell you if it can be done. The other option is to have the end of the crank enlarged. Either way you will need the original early flexplate.
PS: The problem is not just with the 170 engine. It rears its head with the 1967 and earlier 170, 225 and the 273 V-8.
PostPosted: Fri Jan 27, 2017 5:22 am
Thank you for the information. I will research what year 170 I have.
I was told by a local torque converter builder that due to oiling passages
and thickness issues if machined, it can't be done. I will call DACCO to
confirm this today.
Unfortunately, the motor is all assembled. Looks like it has to come
apart to drill the crank. Do I have the machine shop make it the same
as all post '68 slants ?
PostPosted: Fri Jan 27, 2017 8:27 am
Bummer. I have had a few non-LU converters made with the small hub on a late trans, but not a LU converter. Most converter places won't do the small hub in large input shaft anymore, even for non-LU. Midwest converter did one for me last (2008?), and all of the ones I have are rock solid and no problems. You might call Midwest and talk to them before you pull the engine/crank.
Best,
PostPosted: Sat Jan 28, 2017 5:53 am
Well, research shows in fact a small pilot hole 170 crank. I called Dacco and was informed it is not possible to mate or adapt a small pilot hole crank to a 904 lockup. It appears I have self inflicted the rookie learning curve and will have to disassemble and drill the crank.
Charlie S mentioned that the 170 flex plate is unique. My motor was a manual trans. I have 225 flexplates What is unique about that 170 flex plate ?
Thanks again for all your knowledge.
-- Mike
PostPosted: Sat Jan 28, 2017 9:36 am
You can use you current flywheel / flex plate if you end-up machining-out the back of the crankshaft. (open-up the counter-bore)
The remaining support area gets thin but it works.
(see photo below)
Mopar did make a "big hub" 170 crankshaft... (1968 & 69 only)
You would need the matching larger hole flywheel / flex plate if you used one of those.
PostPosted: Sat Jan 28, 2017 3:38 pm
-- Mike
The 170 flexplate is not unique. You need the flexplate that matches the flange on the crank.
1967 or older 170 or 225
1968 or newer 170, 198 or 225.
PostPosted: Sat Jan 28, 2017 3:43 pm
Yep, I have one of these. It is for a NOS 170 engine I am assembling. All NOS parts, nothing aftermarket, or rebuilt/refurbished.
 Post subject: Nos 170
PostPosted: Sat Jan 28, 2017 6:29 pm
Even the head?
PostPosted: Sat Jan 28, 2017 7:27 pm
Charlie, it wouldn't surprise me to learn that you pounced on at least one of those NOS-in-crate 1970-model 170 short blocks that were for sale some years back.
PostPosted: Sun Jan 29, 2017 4:45 am
Actually, I got it from someone that posted it on this site several years ago. As near as I can tell, everything is new. Block, crank, cam, timing set, timing cover, damper (This was all assembled). Fully assembled head (no rocker assy). Pan, and valve cover. Since then I have aquired 6 rods, rod bearings, std pistons, rings, oil pump, gasket set, push rods, rocker shaft, and rockers. All are NOS. The only thing I don't have is a NOS distributer/coil, and fuel pump. It was offered "free to a good home". So far I have about $300 in it. It is a labor of love. I wanted to see if it would be possible to build (possibly) the only NEW 170 motor in existance. It has been interesting, locating NOS parts at prices I could afford. The rods were the hardest thing to find, particuly the last two.
PostPosted: Sun Jan 29, 2017 6:06 am
Would there be anything to be gained by machining a collar to go on the outside of the hub if it ends up so thin ?
-- mike
PostPosted: Sun Jan 29, 2017 6:32 am
There is no load on this surface, so I would not worry about thinness in that region.
PostPosted: Sun Jan 29, 2017 7:43 am
X2, right. The hub register in the back of the crank is there to keep the
torque converter aligned "on axis" w/the crank centerline, once you've
tightened the flexplate bolts, that's where it stays.
