It is currently Mon Jun 22, 2026 8:21 pm
 Post subject: Too torquey Super Six?
PostPosted: Thu Apr 08, 2004 11:50 am
Howdy again all! Some may remember, I swapped a Super Six/OD four speed into my '68 Valiant, and have been loving it! I blew the old 7 1/4 apart after swapping it in, so it must have some good "pep" in it.
My question, the engine/tranny moves around too much on hard acceleration, enough where it affects the Z-bar alignment/clutch pedal. I can watch the tranny torque over (still have the hole in the floor :roll: ), and easily see it in the Hurst shifter wigglin' around. New motor and tranny mounts, and everything seems tight.
Anyone else have this problem before? I am considering putting a torque strap on the engine, or getting a solid motor mount, as the driver's side motor mount looks very similar to a small block mount. Anyone done either of these before?
Thanks all!! :P
Scott - waywardgarage.com
Why is the rum always gone? Image
PostPosted: Thu Apr 08, 2004 11:56 am
Also, at higher speeds, I believe the torquing over is causing a mis-alignment and thus "shaking" tranny problem, but it could be the OD A-833 falling apart internally, or my u-joints. I'm going to pick a spare driveshaft up from the wrecking yard and have new u-joints pressed in later, should do that anyways, see if that clears up that problem. Not sure if its related, but I figured I'd mention it anyways....
PostPosted: Thu Apr 08, 2004 12:00 pm
I'm gonna go out on a limb and say you have a problem with your tranny mount. I know you said it's new; but... that doesn't mean it's good.
My truck is a Frankenstein creation
Built from the dead carcasses of others
And brought BACK TO LIFE!
PostPosted: Thu Apr 08, 2004 1:39 pm
I have seen a new poly-material trans mount offered, that could help.
As for solid engine mounts, that will be way too harsh for a street car.
A torque strap is the best solution to the problem.
PostPosted: Thu Apr 08, 2004 11:22 pm
and here i thought torque was a good thing guess not when it starts breaking stuff
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Fri Apr 09, 2004 2:19 pm
Car Model: 62 Lancer GT
I put an od tranny in last year and my shifter wobbles around (a lot) at idle to. The engine runs smooth as can be. Haven't had it on the road yet though. I'd like to hear the answer to this one.
1966 Dart GT
4 spd. OD conversion
8 3/4 - 3.55 SG (Sold)
62 Lancer GT
B Body 8 3/4
