It is currently Sat Nov 21, 2026 8:03 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Wed Oct 05, 2005 5:58 am
I'm not sure what you mean when you ask "can you use any carb". When a propane mixer is attached to a throttle body (the part of a gasoline carburetor that contains the throttle valves) it becomes a propane carburetor. With the right adapters, you can attach a variety of mixers to a given throttle body. Every mixer was designed for a specific flow so it is important to select a mixer that is properly sized for the engine.
For dual fuel applications, you can mount both straight and dual fuel mixers upstream of the carburetor if you have the right adapter. However, a lot of the straight propane mixers sit directly on top of the carburetor which could obviously cause hood clearance problems.
PostPosted: Wed Oct 05, 2005 10:06 am
The question should have been something like this:
Does the propane mixer care if it sit on top of a gasoline carb, or if it is mounted directly on a throttle body :?
I don´t see much difference, but have to ask anyway...
PostPosted: Thu Oct 06, 2005 5:47 am
The propane mixer doesn't care where it sits.
However, depending upon the restrictions that lie upstream of the mixer, you may want to connect the vent of the converter to the balance port of the mixer. In this way, the converter "sees" the same air pressure as the mixer.
PostPosted: Thu Oct 06, 2005 12:43 pm
Sounds good to me :D
PostPosted: Wed Feb 08, 2017 12:50 pm
Generally, you don't install a dual fuel system for the performance. Obviously, the main reason to convert is to save money on fuel and this only makes sense if you drive enough and there is a big enough spread between the prices of the two fuels. Even with the slight loss in power, there is still plenty available for normal driving. I have a sample calculation you can do on my conversionspage to see it it makes sense for you.
You do regain some of the power of the engine by increasing the compression ratio and 10.5:1 is a realistic limit because of propane's 104 octane number. However, you are right about this not being realistic for a dual fuel engine because you would also have to run high octane gasoline. The performance loss actually comes from the gaseous fuel displacing some of the air required by the engine rather than from its lower energy content per gallon. Interestingly, propane has a higher energy content per lb but its lower density results in the lower energy content per gallon.
As far as performance goes, I know of one propane drag racer. Gas Injection Technologies in Australia have conversions(not available here) that outperform gasoline systems.
1965 Plymouth Barracuda,
225 engine, Quadrajet, HEI, Dutra Duals, 904 Torqueflite, 2.76:1 axle, Addco front bar
Rods & Relics - Fort Erie, ON / Collector Car Tech
