It is currently Sun May 03, 2026 4:25 am
Post new topic  Reply to topic  [ 52 posts ]  Go to page Previous 1 2 3 4
PostPosted: Thu Dec 29, 2016 4:45 am
Wait, let me get this, um, straight... You sent the original K from this car to Firm Feel and they gusseted it and sent it back warped/bent? Seems like they should provide you with a good stock K or give a partial refund, or take your K back and sell it themselves.
Just a thought...
PostPosted: Thu Dec 29, 2016 9:19 am
Just a thought...
I am reading he pulled the FF one out of a wrecked car. He still has the original for the car he has. :shock:
PostPosted: Thu Dec 29, 2016 10:01 am
Sorry, i guess I haven't made this mess clear.
My brother has a 74 Duster project car with a factory slant six K frame. The Duster is straight and has never ben in an accident.
Several years ago i parted out a 1968 Dart that had a 73-76 spool mount K frame installed by the previous owner. The previous owner had had the K frame reinforced by Firm Feel (I think). The K frame is attached to reinforced LCAs and has the thicker C body tie rod sleeves.
The 68 Dart was in a bad accident where the front end hit a cement barrier and it was totalled. I had hoped to use the reinforced K frame from the 68 Dart in my brother's 74 Duster but it turns out that the reinforced K frame is bent.
I contacted Firm Feel about straightening the bent K frame and they said they coudln't do it.
I still have the stock, straight, unmolested K frame from the Duster and that is what i will be using. I had planned on giving the Duster K frame to a board member whose K frame cracked. however, since I need to kepp the Duster K frame for the Duster, I am sourcing another K frame for the board member. I believe I have found another K frame in Arizona that will be shipped to me.
I still can't weld, though. :wink:
Hopefully that clears things up. I have a tendency to overcomplicate descriptions and get involved in complicated transactions.
PostPosted: Fri Dec 30, 2016 4:15 am
OK, clear as mud, thanks.
PostPosted: Sat Feb 11, 2017 12:02 pm
Dang, that's what I thought. OK, back to the drawing board.
Go ahead and get a torch kit.
You can get them in a bunch of different sizes.
You will be glad you did.
PostPosted: Sat Feb 11, 2017 12:07 pm
An oxy/acetylene rig is on my wish list, but I need to (a) make room in my garage and (b) save up enough money to get one. For now I am going to strip what I can off the bent K frame and turn it into an engine stand so I can run motors out of the car.
PostPosted: Sat Feb 11, 2017 12:39 pm
Wish in one hand... you know the rest :evil:
They make small tank sets for the hobbyist,
spend the money on a good torch first.
Oxy/Acetylene is great practice for mig welding.
A motor stand is on my list of garage toys.
I was thinking an old truck frame. :twisted:
I could put a hitch where the cab used to be and it will be portable. :roll:
I like bothering folks and I'm bored. :shock:
The wood burner in my shop needs repair. :(
Do what you think is right.
Glad you got it sorted anyway. :D
Have fun son. :lol:
