It is currently Sat May 02, 2026 5:21 pm
 Post subject: New Leaf Springs
PostPosted: Fri Mar 17, 2017 7:04 am
swapping out the 7 1/4 for an 8 3/4, getting it narrowed now, axles and break rebuild kit on the way from Dr. Diff
while at it I am looking to install a new set of leaf springs
69 valiant /6, gears are 3.23 sure grip, will likely lower the gears in future
what leaf springs do folks recommend for a weekend/daily driver
espo? mancini http://www.manciniracing.com/maaexhedules1.html ? or one of the numerous other vendors?
espo is something like $360 for a six leaf spring, mancini $235
just want a decent ride down the road, thru the corners, and be enough overkill for now that if I decide to seriously upgrade the engine later that I will have things covered
thanks,
austin
PostPosted: Fri Mar 17, 2017 1:39 pm
I advise getting a 5 leaf spring. 6 is really overkill and will make your car loose/twitchy and give a hard ride. It will not handle better. Espo should be less for 5 leafs and I have heard good things but never used them. If you want an upgrade, then I believe the Hotchkis "geometry corrected" (slightly lowered and a stiffer but not too much) would be good. More expensive...
PostPosted: Fri Mar 17, 2017 3:21 pm
Cheap and easy
JR Spring from JC Whitney
PostPosted: Tue Mar 28, 2017 8:00 am
Just thought I would drop a follow up line.
I ordered a set of springs from Mancini Racing. Springs and related hardware seem just fine at this point but the customer service from Mancini Racing is somewhat skeptical.
I ordered a set of rear shackles, http://www.manciniracing.com/maraboshset.html $34.95
I received a set of rear shackles looking identical but was charged $59.95 .
Called them to inquire, and they told me that that part was no longer available. I informed them it is on their internet site for sale and that is what I had asked for and I was told these were poly eurothane .
Pretty much got the oh well sort of response, although the man did not say that specifically.
when ordering parts in future, will likely try elsewhere first.
Austin
