It is currently Fri Jun 12, 2026 6:16 am
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Mon Mar 06, 2017 9:23 pm
Do I need to make the ring gap larger (and the top 1 or both rings?) and how much for 8-10lb boost max? .005 enough? I know I did about .008 when I supercharged my 440 but that was years ago and thing might/did change so I want to get some info on the turbo setups and changes needed to help me survive with this engine.
I don't know anything about turbos, but that doesn't sound like nearly enough ring gap. I think the rings I put in my Dart's engine (NA) were something like .015" out of the box, and I probably filed them out to .030". Granted, the car is an endurance racer and gets run hard for hours at a time, so I figured better safe than sorry.
Escape Velocity Racing
PostPosted: Tue Mar 07, 2017 11:09 am
oops sorry I meant an extra 5 to 8 thou over the normal ring gap that I would normally file .
 Post subject: Slants and a turbo
PostPosted: Sat Mar 18, 2017 2:30 pm
I can say that for the lack of knowledge I have on my motor, I do run a large hx35 on an otherwise stock slant at 10# of boost. The engine I picked up in ohio and the guy couldnt remember anything about it. So the most I know is by looking at the pistons through the sparkplug hole and they so a 40 over bore. Now for ring gap and compression etc I have no clue but I can say that I have run 8-10# of boost for over a year with no issues. I have a huge fmic and timing pulls back to 18* max. I run 87 cheapo gas and keep my af about 10 while in boost. I lean out a bit to about 13 afr when hitting about 3800 rpm then I shift. This is mainly bc im running boost referenced stock mechanical fuel pump. So I guess my input to this is, yes it would be nice to be spot on for numbers down to the cc or thousandths but You can be off by some and still survive. I would personally stick closer to 9 to 1 than the 8 since its a dr and youll benefit from the off boost compression amd let the turbo pick up the slack "when needed" as long as you have timing and fuel correct, I have seen no reason why a 9to1 slant wont take 10# of boost. And believe me, youll smile ear to ear when you feel the 5-10# boost build 😈
225, Offenhauser, Holley 350, A833OD, 3:55, GM HEI,99 Durango starter
BOOSTED! WH1C, BIG FMIC, 10#
Operation Noble Eagle 03-05
Operation Iraqi Freedom 05-07
Operation Enduring Freedom 12- 13
