It is currently Wed Jun 17, 2026 10:13 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Wed Mar 29, 2017 9:08 pm
Got it out! As suggested, I used a center punch against the exposed edge of the flute to counter-rotate the bit. It was still a little too tight to slide out, so I used a diamond-tip dremel cutter to grind a small indent on the OD, where I seated the punch to tap the bit backwards until it was loose. Had to grind a new indent a couple times, but eventually it was loose enough to slide out the rest of the way.
Once that was done, I finished drilling out the oil passage with a new drill bit. Mama didn't raise no quitter... and I didn't want to leave any rough edges in there. Of course, this time I did it much more carefully. The whole reason the last one broke is because I got impatient and careless on the last hole.
Next up is cam bearing installation, then I'll start putting everything back together. Ideally, this thing will be running next week.
Escape Velocity Racing
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 4 guests
