It is currently Wed Apr 29, 2026 2:09 am
 Post subject: LBP and SBP
PostPosted: Sat Apr 01, 2017 1:45 pm
Car Model: 62 Lancer GT
Can I run big pattern on rear and have small bolt pattern on front?
1966 Dart GT
4 spd. OD conversion
8 3/4 - 3.55 SG (Sold)
62 Lancer GT
B Body 8 3/4
PostPosted: Sat Apr 01, 2017 1:57 pm
Sure. You will just have to carry two spares -- one for each bolt pattern. You might also look into wheel bolt pattern adapters for the front and run LBP front and back.
PostPosted: Sat Apr 01, 2017 4:11 pm
Its pretty easy to change the front.
The larger pattern give many more options.
PostPosted: Sat Apr 01, 2017 6:14 pm
I will do the front at some point, I found a 7 1/4 with posi that Im thinking of buying and it has BBP.
1966 Dart GT
62 Lancer GT
B Body 8 3/4
PostPosted: Fri Apr 28, 2017 1:36 pm
That gives you a good excuse to do a front disc brake upgrade in the future. Most people looking at that swap have to consider the opposite problem (LBP in front, SBP in back).
Escape Velocity Racing
