It is currently Sat Jun 13, 2026 10:41 am
 Post subject: Camshaft HELP
PostPosted: Sun Apr 16, 2017 9:08 am
I,m have installed a new cam, and having problems setting the valves. I bring the number one piston to the top with the timing mark on zero, I check for the piston with a piece of wire, that's all I have. the cam call's for exhaust set at 22 and the intake set a 20, when I run through and set all the valves by turning the engine 1/3 turn at a time for the cylinders, I notice that some of the exhaust push rods are almost falling out of place, so the engine would not start, I took the valve cover off and found that all of the exhaust push rods have fell out of place.....I don't understand why
Mike
PostPosted: Sun Apr 16, 2017 9:46 am
6 Pack Dart
You might look at the point you might have used the #6 cyl was ready at that not #1 cyl , check that you have both valves closed ( lifter or push rods down on #1).
Richard
PostPosted: Sun Apr 16, 2017 10:11 am
Richard
Yes both valves are closed
PostPosted: Mon Apr 17, 2017 12:24 pm
I got it, I followed a you tube video from Comp cams and it work.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
