It is currently Sun Jun 14, 2026 1:17 am
PostPosted: Thu Apr 20, 2017 7:44 am
Degreeing a camshaft.
Ive spent hours trying to figure out why when using the @.50 procedure for degreeing my comp cams camshaft I cant get correct readings and then when using the intake centerline method I hit very close to the correct specs the very first time.
Nothing changed in my setup, nothing moved. I just recorded the readings a different way.
Ive read online that the @.50 is the preferred more accurate way and this is the way I would like to be able to do it.
PostPosted: Thu Apr 20, 2017 7:50 am
Car Model: 75valiant custom
wanna put that in layman's terms so the rest of us can learn what in the world you are talking about?
PostPosted: Thu Apr 20, 2017 8:27 am
That's what I do - at 0.050" Lift Before and after the max height of the Lobe height. not 0.050" off the Base Circle like Duration in cam cards Duration at 0.050"
I also Like to do this with Full valve spring on the Valves etc, Just my preference.
Make sure you have a steady Dial Indicator etc. I measure at Valve (on the valve retainer) with head on / installed on the engine......not from just the Push rod or lifter.
I hope this all makes sense.
I am not sure what others do or If what I am doing is correct or not.
Ask 10 engine builders and you might get 9 answers and they might all be correct.
PostPosted: Thu Apr 20, 2017 8:38 am
Thanks for the response, I got it figured out by calling the place that I was using the instructions from ( online ) and they told me their directions were missing some steps.
We got it all worked out and now I can measure it both ways and get almost the same results.
For more info on degreeing your camshaft see here http://www.forabodiesonly.com/mopar/thr ... ng.377949/
PostPosted: Thu Apr 20, 2017 10:00 am
Cool. I use a pushrod off the lifter directly. Yes, many different ways...
PostPosted: Thu Apr 20, 2017 1:35 pm
Missing steps can be tricky...
Good luck.
PostPosted: Thu Apr 20, 2017 1:59 pm
I have two lifters epoxied together, cup to cup. (to get a flat surface). Dial indicator directly on the lifter, then like Greg .050 before, and .050 after max lift. Then double check against the cam spec card, intake and exhaust. At one time, I did find a cam not ground to the specs on the card. Lobe separation was off.
PostPosted: Thu Apr 20, 2017 4:16 pm
The lobes aren't symmetric.....
The larger the angle between the .050 measuresments, the more an asymmetric lobe will show a difference.
 Post subject: Yep...
PostPosted: Thu Apr 20, 2017 5:27 pm
That's how I do it, with the .050 on each side.
