It is currently Thu Nov 19, 2026 8:02 pm
 Post subject: truck vs car 904
PostPosted: Thu Apr 06, 2017 7:06 am
is there a physical difference between a car A904 and a D150 A904?
I know the tail shaft length changes for the manual A833 trannys between an A body and a truck, does that carry over to the auto's?
PostPosted: Thu Apr 06, 2017 9:35 am
No, the 904 stays the same length. The only change I know of in trucks is the short tail 727 in a 4wd application. :D
PostPosted: Thu Apr 06, 2017 1:08 pm
so,, is there a way to tell if a slant six A904 is from a car or from a truck?
PostPosted: Thu Apr 06, 2017 3:36 pm
If you have the numbers off the pan rail you can decode them. I am no expert in that though. :(
 Post subject: Yep...
PostPosted: Thu Apr 06, 2017 6:41 pm
You have to watch that too... I got a 225 and A904 from a 1970 Dart for cheap, slant had a hole in one piston... the A904 was workable... looked up the numbers and it was something like 4130413 on the pan rail...
It crossed to a 1979+ lockup A904... I opened it up to adjust the bands and look over the valve body... oddly, no lock up assembly... everything on the inside was just like the Pre lockup units....
PostPosted: Sun Apr 23, 2017 5:08 pm
PostPosted: Sun Apr 23, 2017 5:25 pm
PostPosted: Sun Apr 23, 2017 5:35 pm
PostPosted: Mon Apr 24, 2017 2:45 pm
PostPosted: Mon Apr 24, 2017 2:48 pm
PostPosted: Mon Apr 24, 2017 3:15 pm
PostPosted: Mon Apr 24, 2017 3:18 pm
PostPosted: Mon Apr 24, 2017 3:21 pm
PostPosted: Tue Apr 25, 2017 3:10 am
4058383 A904T was the number for trucks from 1981 till 1985
