It is currently Wed Jun 24, 2026 10:50 pm
PostPosted: Mon Apr 24, 2017 11:10 am
Take some more pics of the fender wells (both) and the firewall area. It has to have some sort of ignition retro-fit installed if it runs at all. Someone will be able to identify the ignition source.
There is a Module of some sort behind the battery mounted inside the fender well has about 10 wires going to it..I see No other source anywhere for ignition so maybe that's it..When my wife gets home with the smart phone i will upload a better pic of the module
http://i1319.photobucket.com/albums/t66 ... j5pml7.jpg
Here is another of the plug that is supposed to be plugged into the distributor i suppose...Looks like i have a mess to figure out..But for what it's worth it run's very good but i want my vacuum advance fixed..
http://i1319.photobucket.com/albums/t66 ... ufqbd2.jpg
PostPosted: Mon Apr 24, 2017 12:00 pm
Car Model: 1986 D100 /6 A833od shortbox
That would be it. Same location on my 86. I have had the same plug hanging from my truck's wiring loom near the dizzy since I have owned it. From what I found in the FSM, that is a dizzy plug for the vehicles built for California emission. I'm in Minnesota, hence, there was no need for the plug
86 D100 short bed A833, lean burn deleted.
07 Honda Accord EX-L V6
03 Toyota Highlander - 305k and still going strong
13 Toyota Highlander - 151k
PostPosted: Mon Apr 24, 2017 12:14 pm
So what i need to do is change out the Dizzy with a vacuum advance and finish the hei conversion..Then i will be set
PostPosted: Mon Apr 24, 2017 3:07 pm
And probably swap to an older carburetor with the correct ported vacuum advance for the distributor and make sure that the electric assist for the choke thermostat still works properly.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 3 guests
