It is currently Sun Dec 28, 2025 6:47 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Thu Apr 27, 2017 8:36 am
Car Model: 1964 Plymouth Valiant 225, 1977 Dodge D100 225
Thanks, Lou! This is exactly what I needed to know. :D
Chuck and the Flying Valiant
PostPosted: Thu Apr 27, 2017 4:30 pm
Just a little side note- if you have any exhaust system leaks upstream (or within 12-18 inches downstream) of your oxygen sensor, that will skew the reading towards lean. As exhaust pulses go through the system, you have "low" pressure waves that will suck outside air (oxygen) into the system. Especially at low flow conditions such as idle.
Heck, the leakage past the heat riser valve shaft on a stock slant manifold would likely be enough to mess up (lean out) the reading some.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Thu Apr 27, 2017 7:06 pm
Yes, no leaks allowed. The other thing is that if you are way too rich (>10:1 AFR or so), then it can put the fire out (misfire) and look lean. Both WB and NB suffer from these problems, so don't give up on your personal sensors and intuition...
