It is currently Thu Jul 16, 2026 5:27 am
 Post subject: Wipers Don't Work
PostPosted: Mon May 01, 2017 11:48 am
All of a sudden my wipers don't work. I see this thing under the dash dancing around when I turn on the wipers. I believe it should be sitting solid, instead of free. Where does it hook up to?
PostPosted: Thu May 04, 2017 8:56 pm
:shock: :shock: :shock: :shock: :shock:
The rest of the car!!!!!!!!
Or maybe more accurately the rest of itself!!!!
Looks like the housing is off the mounting plate, any screws loose &
visible or on the floor?
PostPosted: Thu May 04, 2017 9:03 pm
I would also check that oil gauge line closely & be sure it wasn't damaged
or pulled from the gauge some....................
PostPosted: Thu May 04, 2017 11:46 pm
Oil line is fine. Where is the mounting plate? And what does it look like? Thanks.
PostPosted: Fri May 05, 2017 6:24 am
Thanks killer6. I took many photos under the dash, and see what you are talking about. So now I know what to do. I appreciate your input.
