It is currently Sat Jul 18, 2026 9:21 am
 Post subject: 14" Wheel Options
PostPosted: Tue May 09, 2017 9:53 am
Car Model: 1973 Dodge Dart 4-Door Custom Sedan
Hello:
I'm thinking that I'd like to use my original 1973 hubcaps on my Dodge Dart, but I'd like to get wider tires. I'm wondering if I can get a set of wider 14" steel rims, upgrade the tires and use my standard hubcaps on them.
Thoughts?
Thanks, Shawn
 Post subject: Re: 14" Wheel Options
PostPosted: Tue May 09, 2017 10:05 am
Hello:
Thoughts?
Thanks, Shawn
YEs this Can be Done
I have successfully Run 225 70 14 on 14X5.5's They are Better on 14X6's or 14X6.5's
Stock Caps or full wheel covers will still work. YOu may need to get aftermarket or custom Wheels.
PostPosted: Tue May 09, 2017 10:20 am
Hi!
Thanks! I was hoping that was the case. I am trying to utilize as many original parts as I can and think that better tires on a wider rim (with the original hubcaps) would be ideal.
Shawn
