It is currently Sat May 02, 2026 8:23 am
 Post subject: Stumped
PostPosted: Fri May 12, 2017 6:00 pm
74 dart 225 all stock
Died on highway, hauled home, replaced ballast resistor fired right up
Died in highway next day, assumed coil was breaking down, put in new coil fired right up, not
Will star when cold. Runs a few minutes and then dies
Has newish voltage regulator on fire wall, less than six months
Not getting fire
Where to check next?
I know new does not mean good parts, but tired of replacing parts rather than fixing car
Thank you for your replies
PostPosted: Fri May 12, 2017 6:35 pm
Ignition module and distributor pickup coil (inside distributor) are prime suspects for fails-when-hot. To diagnose, wait til car is cold enough to start. Verify it starts, then shut it down. Use a hairdryer or incandescent droplight to heat up the ignition module -- good and hot. If the car doesn't start, you've found the culprit. If it does, repeat the test but heat up the distributor pickup coil instead.
PostPosted: Sat May 13, 2017 3:13 am
Thanks Dan.
I think ignition module and will report back the results
PostPosted: Sat May 13, 2017 7:38 am
Pull the bulkhead connector apart and check the blades for corrosion. The blur ignition wire being corroded is very common. If nothing else, pulling the connector is free. :D
PostPosted: Sat May 13, 2017 12:30 pm
Module it was.
Thanks again
