It is currently Wed Nov 18, 2026 8:40 am
PostPosted: Mon May 15, 2017 12:50 pm
The rear cooler line fitting on my 1966 valiant is completely gacked and stripped, but I can't figure out how to get it out sans removal of the trannie. Anyone got any tips for that? The darn thing has a home in one of the most inconvenient of spots.
PostPosted: Mon May 15, 2017 1:17 pm
You may have to snip the line to allow getting onto flair nut with a female easy out. This is a gizmo with left hand twist thread that bites into a mangled nut or such that is used with a socket ratchet.
Something like this.
Than you can make a new line to replace the whole thing**, or splice onto the old line with new fittings and a short length of tubing.
** Replacement may cause more problems when removing the end fitted to radiator...
PostPosted: Mon May 15, 2017 1:48 pm
I already got the cooler lines out, it's the fitting in the transmission itself I can't get to. It's an elbow type and it's in a nasty spot lurking above the oil pan, muffler, and xmember
 Post subject: You can...
PostPosted: Mon May 15, 2017 5:48 pm
Sometimes get a little more room, by loosening the motor mounts a bit and removing the rear crossmember so you can lower the rear of the tranny a bit or use a jack to roll it a bit one way or another... (you may need to keep an eye on the exhaust, B&T joint, radiator hoses or firewall electrical, etc depending on how much room you need and how much "tilt"...)
Users browsing this forum: Bing [Bot] and 5 guests
