It is currently Wed Jun 17, 2026 1:39 am
 Post subject: TSB exhaust manifold
PostPosted: Sun May 21, 2017 5:26 pm
PostPosted: Sun May 21, 2017 5:41 pm
Note the outlet id just a little smaller than older manifolds.
PostPosted: Mon May 22, 2017 12:18 am
How can you tell ID just by what you posted?
PostPosted: Mon May 22, 2017 10:32 am
Says who?
PostPosted: Sun May 28, 2017 4:12 pm
Manifolds with this number 4100448 and dates 79,86 and 95 1 and 15/16 outlet. 2 manifolds with this number 4027567 from 1977 and one manifold with number 8 or 3 671882 from 1973 had 2 inch outlet.
PostPosted: Sun May 28, 2017 4:18 pm
Is 1/16 difference in a cast iron exhaust manifold inner diameter intentional or manufacturing tolerance? Maybe some of the older cores were wearing out and resulting in a slightly smaller inner diameter?
 Post subject: Manifold number
PostPosted: Sun May 28, 2017 4:19 pm
 Post subject: Drill hole in intake
This kit comes with instructions,
PostPosted: Sun May 28, 2017 4:20 pm
PostPosted: Sun May 28, 2017 4:29 pm
Last 4267233 I measured was a good number of years ago, but I recall it being the same as the '65 manifold I was comparing: 2" even.
In any event, if you encounter one with a 1-15/16" outlet, take a cylinder hone to it and get back your 2". :-)
