It is currently Sun May 17, 2026 11:44 am
PostPosted: Thu Jun 01, 2017 8:14 pm
This is probably a question I should have asked years ago. We run a pretty big trans cooler on the LeMons Dart, which has a mostly stock 904 with a deep pan. I only say "mostly" because the valve body may have been mildly breathed-upon for firmer shifts when I had it rebuilt back in college... but I honestly don't remember. It's all stock clutch packs, no V8 guts or anything. We leave it in Drive for races.
I don't think I've ever seen the trans temp get above 150 °F during a race. More often it's closer to 140. Is that too cool?
Escape Velocity Racing
PostPosted: Fri Jun 02, 2017 4:18 am
Yes, it can be too cool. You can look up the optimal operating temp for an old school automatic, but IIRC it is 180-200 F. However, if it has lasted this many races, I might just leave everything alone!
PostPosted: Fri Jun 02, 2017 7:12 am
I would be suspicious of your temp measuring system, that temp doesn't add up, Are you in Alaska? :D
PostPosted: Fri Jun 02, 2017 9:00 am
Yeah, I agree it does sound very low for something getting that kind of workout, even with a big cooler. Might be the sensor is bad. Are you reading temp on the fluid output of the trans or closer to the input?? You want the output...
PostPosted: Fri Jun 02, 2017 9:20 am
Online
180-200 is optimal. 160 is not unusual.
I can read trans temp on my Challenger, it rarely gets above 180, and it takes quite a lot of driving to get it there. :D
PostPosted: Fri Jun 02, 2017 12:04 pm
Sounds like a WHACK gauge!
What does the "Water" temp run at usually?
1964 Dart GT
PostPosted: Fri Jun 02, 2017 1:48 pm
Also, what kind of trans fluid are you running? Some people are under the mistaken belief that Type-F fluid is "superior" -- it is not; it's an archaic fluid that is severely inferior in absolutely every performance and durability characteristic. Today's Dexron-VI handles higher temperatures than yesterday's fluids (viscosity doesn't change, varnish and sludge don't form).
PostPosted: Fri Jun 02, 2017 5:43 pm
:oops:
Yeah, the temp sensor is mounted in the pan. I suppose that's not a very useful measurement, then.
PostPosted: Fri Jun 02, 2017 6:53 pm
No, that should work, is it electrical or mechanical?
Do you have access to a thermal temp gun, just read the pan when hot, it should be close/slightly lower then your gauge reading,just to verify whats going on.
PostPosted: Sat Jun 24, 2017 8:46 pm
I just checked out a '10 F-150 Lariat w/the trans temp gauge function, I hit
trucks and cars w/a pretty harsh road test, if it's gonna slip or shudder hot
I want it to be on Me....not a customer after purchase...happened once on
a Chebby to Us already( converter clutch bits plug-up the cooler).
On the test (approx. 9 miles) the temp was hovering right around 150deg.
when I pulled it into My bay. I wouldn't lose one millisecond of sleep over it.
