It is currently Mon Nov 23, 2026 10:21 pm
 Post subject: For Corners
PostPosted: Thu Apr 27, 2017 11:12 am
Is this a recommended part for 64 Darts?
https://www.summitracing.com/parts/aco- ... structions
Are there better Options or is this one good?
PostPosted: Thu Apr 27, 2017 1:18 pm
There are better (and more expensive) options, but that's the one I have on my 64' Dart LeMons racer. The only real downsides to it are the crappy mounting brackets. I think Lou is the one I saw in an old thread talking about how to improve the mounting situation.
Escape Velocity Racing
PostPosted: Thu Apr 27, 2017 1:19 pm
That looks the same as the others.
You will need to re engineer the K mounts, ( 2 pieces of angle)
PostPosted: Thu Apr 27, 2017 1:51 pm
Cool.
I can re engineer things... thats easy.
Yay welding😀😀
I bet i can get this thing Skookum asFrig in no time.
I think lou will chime in as well.
PostPosted: Thu Apr 27, 2017 2:21 pm
That looks like the same mounting brackets and instructions that Addco had in 1989-1990 when I bought my first one for my 68 Dart, and again in 1998 when I bought the second one for the 64 Dart. Ugh.
If you can spend that, then spend a few extra bucks, save 5-8 lbs (tubular), and get better mounting brackets.
https://www.summitracing.com/parts/hel-55914
I just put one of these (for later Dart) on my 68. I still had to mess with the brackets a bit (weld/shim/adjust), but the hardware was so much better than the Addco stuff.
PostPosted: Thu Apr 27, 2017 3:14 pm
So... ditch addco. And get hellwig?
I like lighter.
PostPosted: Thu Apr 27, 2017 5:27 pm
Here's the addco fix:
Addco just uses the bottom bolting (angle iron bolted to K-member,bottom A/R mount to angle iron). The fix is to also bolt at top as shown.
PostPosted: Sat Jun 03, 2017 9:18 am
Careful not to let the shmoo out of 'er, wa.
63 Valiant 200
64 Dart 270
73 Fury II
84 Cherokee 2 dr
86 Dodge W-150
73 Volvo 144
74 Volvo 145
81 Volvo 245
PostPosted: Sat Jun 03, 2017 10:01 am
Givver!
PostPosted: Sat Jun 03, 2017 11:24 am
Anybody else out there an AvE fan?
Greg, I met you briefly at Mason Dixon. I was the tall guy who mistook you for a dude I was supposed to meet who called his car the "Ruster" also.. Turns out he didn't have it written down the side of his door. I didn't put two and two together until I saw your screen name later that night.
63 Valiant 200
64 Dart 270
73 Fury II
84 Cherokee 2 dr
86 Dodge W-150
73 Volvo 144
74 Volvo 145
81 Volvo 245
PostPosted: Sun Jun 04, 2017 1:31 pm
RELEASE THE SCHMOO. and We'll see if it chooches on the gland end.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 2 guests
