It is currently Sat Jun 13, 2026 12:28 pm
 Post subject: Carb adapter
PostPosted: Sat Jun 10, 2017 9:24 am
Car Model: 1968 Plymouth Barracuda slant 6 super six 4 speed.
Which carb adapter do I need for a 350cfm Holley 2 barrel carb to a slant six super intake?
I'm human and I do things for the universe.
 Post subject: You will need....
PostPosted: Sat Jun 10, 2017 9:42 am
A Mr. gasket #1937 flipped upside down to make the conversion, a gasket for both carbs, some RTV sealant doesn't hurt especially the way the adapter bolts to manifold sit in the adapter can make a nice path for a leak if not gooped....
Also a word of advise one of the outboard holes sits over the manifold and you will have to insert the bolt that will be your carb stud into it before mounting the adaptor... failing to do so will require you to remove it and do it over again....
Good Luck!
PostPosted: Sun Jun 11, 2017 4:15 pm
I made mine out of a piece of billet aluminum and hogged out the intake manifold so the throttle bores lined up perfectly. It took an afternoon with a drill press and a dremel. I later used a carb heater for a Ford dump truck for winter driving. It's been rock solid for 5 years.
