It is currently Thu Jun 11, 2026 12:38 pm
PostPosted: Mon Jun 12, 2017 4:24 pm
What globe type do I need for the 61 Valiant?
Thanks
PostPosted: Mon Jun 12, 2017 4:58 pm
That's a № 1004.
PostPosted: Wed Jun 14, 2017 4:00 am
Thanks. What is the wattage of a 1004?
PostPosted: Wed Jun 14, 2017 8:02 am
It is a 12-watt bulb.
PostPosted: Sat Jun 17, 2017 7:35 pm
Is 15 CP close to 12 watt?
PostPosted: Sun Jun 18, 2017 10:53 am
There is no direct link between candlepower (cp) and wattage. It's like asking "Is 32 degrees Fahrenheit close to two quarts?".
Er...you sound like you're hedging and tapdancing around the question you really want to ask. I'm guessing you might be trying to figure out what kind of an LED bulb to put in instead of the specified bulb, but there's no reason for me to be guessing when you could just, y'know, cough it up. :lol:
PostPosted: Sun Jun 18, 2017 6:20 pm
No, I cannot locate a 1004 bulb, only ones available where I am seem to be 15 CP.
PostPosted: Sun Jun 18, 2017 6:37 pm
1004 bulbs are (still) standard parts store items, but if you can't get it locally, get it here.
There is no such bulb type as "15cp". That describes an amount of light put out by a bulb. There are lots of different bulb types that produce that amount of light, but the one that will fit and work correctly is the № 1004.
PostPosted: Sun Jun 18, 2017 7:32 pm
Thanks
