It is currently Sun Jun 21, 2026 10:52 am
PostPosted: Tue Jul 04, 2017 8:20 am
Car Model: 1982 Dodge W150
Hi all - new member here. Lurker for a while. I just picked up a 1982 D150 with a slant. Been driving it for a couple of days when it sounded like the exhaust flange broke from the manifold. Turns out there must have been a plug in a large hole on the firewall side of the manifold right below the heat exchanger. I did my best with what I had (a brass pipe plug and some epoxy) but that didnt last long from the heat cycle.
Can anyone tell me the thread pitch/dimensions/etc of that hole? I'd like to pick up an iron plug that will hopefully not heat cycle as hard.
PostPosted: Tue Jul 04, 2017 8:41 am
Really the brass plug should have been fine if it threaded into the manifold?
PostPosted: Tue Jul 04, 2017 8:49 am
It threaded in, but loosely. I did my best to figure out interior thread diameter with a caliper and get something close at the hardware store.
PostPosted: Tue Jul 04, 2017 9:19 am
Sounds like maybe it is a late model manifold with the hole for the O2 sensor. Is it a fine thread about 3/4" in diameter?
If so you can get a plug off E-Bay cheap enough. :D
 Post subject: x2
PostPosted: Tue Jul 04, 2017 10:02 am
If this is correct, most auto parts stores should have a steel O2 sensor "plug" that can be installed.
PostPosted: Tue Jul 04, 2017 12:39 pm
It should be a standard 18 mm O2 sensor plug. There are steel ones all over the place, including eBay. Not sure if there's a thread sealant recommended for these.
Escape Velocity Racing
 Post subject: I'd...
PostPosted: Tue Jul 04, 2017 1:10 pm
I used RTV Copper since that's about as high temp as you can get over the counter... after a while driving it'll carbon up and seal anyway...
PostPosted: Tue Jul 04, 2017 5:39 pm
Dorman 65220 oil pan plug (18mm x 1.5 thread, 19mm hex head)
PostPosted: Wed Jul 05, 2017 8:34 am
An oxygen sensor will plug that hole really well and let you run an air/fuel ratio gauge to help tune your motor.
PostPosted: Wed Jul 05, 2017 9:25 am
Awesome - thanks for the info! I'd love to run an O2 sensor as it was my plan for tuning anyways. Hopefully the shop manual comes soon so I can start seeing what the PO did and didn't do when they removed all the smog equipment.
