It is currently Tue Nov 17, 2026 9:06 pm
PostPosted: Tue Jul 04, 2017 2:12 pm
I need to do this in a town almost 2 hours away to drive my car home.
the manual says (helpfully with no pictures) "remove the extension housing yoke seal, then drive the bushing out of the housing using an appropriate driver (Chrysler tool #C-3974 or its equivalent)
Does anyone know what this tool looks like or have a picture?
does anyone know if this means I can change this on the car or if I need to pull the tailshaft housing to get access to the bushing?
 Post subject: tool
PostPosted: Tue Jul 04, 2017 5:44 pm
I have a tool we made, it's basically just a steel mandrel with a shoulder that stops on the bushing. With my tool I would remove the extension housing because the output shaft has to be out of the way. I can send you a picture of my tool is you pm me with your email address.
 Post subject: Yep...
PostPosted: Tue Jul 04, 2017 10:53 pm
Yes.
Correct, I made one similar to a local transmission shop uses that is like you describe.
PostPosted: Tue Jul 04, 2017 11:40 pm
A big socket might work...........
