It is currently Thu Nov 26, 2026 11:15 pm
 Post subject: Engine I D
PostPosted: Fri Jul 28, 2017 9:45 am
I have searched, and looked over the sight, but come up empty. Where i can I find the chart, or info, on IDing a engine block.
I bought an 1966 Barracuda, with a slant 6. It is not the original engine. The numbers stamped into the block buy the alternator are H 225 8 8 81. Is this an 1981, or a 1972, I am stumped.
Thanks barracudadave67
66-B-Cuda S-6
67-B-Cuda 273 4bbl
69-B-Cuda 340 4 bbl
66-Dart project 273 2 bbl
PostPosted: Fri Jul 28, 2017 11:16 am
Is it a hydraulic lifter motor?
PostPosted: Fri Jul 28, 2017 11:21 am
I think it is, It dosnt clack like my mechanical lifter 273. I'd just like to know what year it is. I know it takes the later model valve cover gaskets.
Thanks for your reply.
barracudadave67
66-B-Cuda S-6
67-B-Cuda 273 4bbl
69-B-Cuda 340 4 bbl
 Post subject: Re: Engine I D
PostPosted: Fri Jul 28, 2017 1:55 pm
H 225 8 8 81
H: 1972 model year
225: displacement
8 8: Engine built on August 8, 1972
81: Could also be B1. Shift number, line number, other number not useful for engine ID once it leaves the factory.
PostPosted: Fri Jul 28, 2017 3:45 pm
Thanks Dan, and coconut
Here are a couple of pics of engine, and rats nest wiring before I did somebulk head bypassses, to keep it running.
The valve cover reminds me of late 80s o mid 90s valve covers, with the 008 decal you can make out under all the oil. I have since removed it, installed new gaskets, and repainted it.I put in 1 3/4 in studs with locknuts, and better washers, along with anew fuel line. Carb kit is next. Got rid of all the crimp splices in the rats nest also.
Well I cant see how to add the pics so we'll have to leave them out, I guess.
barracudadave67
66-B-Cuda S-6
67-B-Cuda 273 4bbl
69-B-Cuda 340 4 bbl
PostPosted: Fri Jul 28, 2017 5:30 pm
It does appear that you have a later model head on that 1972 block.
Users browsing this forum: No registered users and 37 guests
