It is currently Thu Nov 26, 2026 6:51 am
PostPosted: Sun Apr 18, 2004 8:40 pm
I am having difficulty in making clean welds after applying weld through
primer on the work pieces. I got a good name brand weld thru
primer because I suspected one might have trouble with a cheepo
brand.
Does this always happen when using primer with a MIG welder?
Any way I am about to sand (or sandblast) off the primer where I
need to make the welds - Any other easier ideas?
Thanks -
PostPosted: Mon Apr 19, 2004 3:26 am
I believe weld thru primer is only intended to be used with a spot welder.
